1 - 8 of 8 Posts
:confused: The blower on my car has stopped working!
The display appears to be ok-well it is lit up and all the buttons work.
But the fan does not appear to be blowing no matter how many bars I have it on.
I have taken the unit out to check for a loose wire,but this unit appears to be 2nd hand as it has LAGUNA 2003 wrote on it.
Am I doomed to replace the entire unit or is there a fuse or relay I can check.
Is there a simple way to check power to the heater fan?
Any help would be great...
Hi yes there is a fuse and relay not sure where but iam sure someone will help soon or try a search to see what comes up hope this helps
Sorry if you have a circuit tester see if power is getting to the motor???if yes its the motor again i believe there a sore point for renault whats new!!!
Just Changed my pollen filter,
If you take the glove box out , just held in with 1 screw and pulls out as its just clipped in. You will then beable to see the blower motor and to the left there is a pannel with a couple of relays and fuses may be these ? not sure but worth having a look.
Gary
HI ALL
Checked relay+fuses all ok.Traced problem to a bad connection on the blower motor plug.
SH*TY French elecrics!!!
Thanks for the help.
I would be interested in the cost for a replacement pollen filter:)
regards
1 - 8 of 8 Posts
