I've recently purchased a 2003 (53 reg) laguna 1.9DCi Int., with climate control. All works fine apart from the LCD display does not have any back lights, so you cannot view the settings in the dark. In the day its OK. I've taken the control panel out, but it looks like the bulbs are integral to the unit. Does any body know of a fix or will it be a search for a new control unit?
Thanks in advance
PSKey29
Great, just looked at the old link, looks simple, will take out unit again, and look at joints. will let you know if if works.
many thanks
PS... good forum....
No problem lagdti.
pskey29, When I did mine I couldn't see a problem with the soldered joints, I did them anyway, and it will work ;)
got a 1.9dci dynamique and need to remove the heater control panel to remove aphone kit, but cant see how to get it out, there are 2 screws behind keycard panel but can't see anymore??
Ive had this problem, and used the forums help, very easy fix just follow the steps given. Im no electronics person and did it with no problem.
Good luck.
