L
Need to do this myself but the link doesn't work, can't fathom out how to get the surround out, I have tried in the past when the flap didn't close on a previous Lag and couldn't get that out either.
Looks simple, one screw at the back but when you undo that, the frame is just as solid as it was before.
Is it simply a case of brute force and hope you don't break it?
Scenic mk1ph2, RX4, ID35s11
pull off side arms from flap, pull flap out and unclip rear clips. remove streeo and tray/sat nav unit.
beyond that your gonna need to refer to the other pages for taking the rest of the inner frame out.
best of luck.
  • Like
Reactions: Yeadi104
