I have tried and tried to prise out the glovebox light unit to replace the bulb, but I can't get it out! Using a mirror, I have prised the tab towards the lens (towards front of car) and it looks like the unit should then drop downwards - but how to apply pressure to do that? I tried poking another screwdriver through the hole that the black plastic plunger pokes through. This is the switch that shuts off the light as the glovebox is closed. I can apply downward pressure and the unit appears to move downward, but the black plastic switch plunger stops it from coming out, because of the glovebox liner. I removed a torx screw at the back of the glovebox, but this didn't let me remove the liner. Has anyone managed to do this???
