:devil: The headlamp leveling system has gone mad, whilst driving it goes up and down constanltly. If you stop turn engine off and take key card out it is then okay for maybe 10 minutes or even an hour. Has anybody come across this problem:confused:
auto level
Hi there,
My guess would be water ingress into the leveling unit which is attached to the rear axle by a rod (n/s). easy to access it whilst the car is on the ground. Remove the connector and look for any blue corrosion in the connecter, and see if theres any stains around the unit.
Hope that helps
Marlster
