Hi - To get the revering lights/sensors to work on my Laguna Previlege I have to push the gearstick slightly further back and hold it. I guess the position of the microswitch is slightly wrong but where is the switch? Is it in the gearbox or is it somewhere accessable. Any help would be very much appreciated
Hello & Welcome to the Forums.
I'm sure someone will be along shortly to assist with your post
Ottoman
switch
Yep if you turn the left side wheel on full lock its tucked up by the driveshaft. you can see the wire going to a green plug.When you unscrew it be careful cos gearbox fluid will leak out so get ready to replace with a new one straight away. and dont forget to top up gearbox when done.Switch is about £7 from renault.
Excellent - thank you very much for the reply. I'll have a look at the weekend. I reckon I'll change the gearbox oil at the same time in case it's sludging up a bit - Peter
Can anyone tell me / show a piccy of where this would be on a 6-Speed 1.9 dci box?
I'm having similar issues with the reversing sensors only working without reversing light bulbs inserted. and if the bulbs are in they glow dim and the sensors don't work at all.
Cheers
MAQ
