Hi All! . I Hope This Is Of Use To Someone. Ive Just Found Why The Passenger Seat Of My 2001 Lag Expression Refused To Recline. After Removing The Seat Covering From The Bottom Of The Backrest By Way Of Two White Plastic Clips Attached To The Seat Base, And Then Releasing The Elasticated Material Clipped To The Bottom Of The Seat Frame, I Discovered That The Rod Connecting The Ratchets Needed To Be Pushed Back Into Its Two Locating Lugs. Job Done!
