PLease help:mad:
My laguna II has a sunroof issue, it packed up a while ago, i ,manually wound it closed cos it failed and was wondering if anyone has any ideas whats caused it.. Itried a different switch and it still doesn't work, can't seem to find a fuse for it either..
Any ideas?
sunroof
how did u close it????
Hi does it operate at all? as I had a problem where by the motor parked in the open position. To cure this I moved the control to fully open tilt and kept the button pushed in for a few seconds this reset the motor memory.May help??
Nice one Baldlaguna - just had same problem, and your fix menat I could shut the roof.
Good dose of WD40 and the turn and press of the button seems to have won the day...
:eek: :rofl: :rofl:
