Have a 2002 Laguna Sport Tourer and after this lovely rain, i now have the added feture of a pond in the passenger footwell.
Have looked at some of the other threads for causes but i doot have a sunroof. Looking at bottom of the passenger door it is wet but the rubber seals appear ok. No water on the interior trim except for a very wet carpet, so no idea how the water is getting in.
Any ideas ?????
Hi there, places where I would look at (or suspect) would be the bottom seal of the windscreen and the bulkhead itself. I would test this out by drying the carpet off, and place newspaper in place. Then run a small stream of water (from a hose, watering can, etc), leave it for half an hour or so, then inspect for watermarks. This should indicate if you are looking in the right area.
Another possibility can be water getting in through the pollen filter housing, this is more difficult to check, and is more reliant on a visual inspection for cracking or poor sealing.
Hope that helps in some way.
Paul:)
