Haynes says it is at "the rear" of the block, but I can't find it. I could just pull the radiator hose off but I wanted to really flush out the block.
Are changing the coolant?.
If so,you can pull the bottom or top hose off the radiator and back flush the system with a hose pipe.Make sure the heater control is turned to hot,and it should flush the heater matrix out too.
