can anyone tell me were i could find the paint code for my 51plate laguna it is a metalic green but need to know the code thanks
Hi there, there should be a sticker on the 'b' pillar on the driver's side door frame - normally located near the sill.
On the sticker, you will find the chassis number, plated weights, and a code (usually preceded with something like MV or similar) - if you can find any such codes - post them, and I'll check my database.
Paul:)
EDIT: Just had a look - the only green I could find which corresponds to your car's build date would have the code 926 or Z13, both relate to a colour called Vert Epicea Effect (a metallic green).
Hope that helps (check the sticker).
Paul
