Yep,I'm 99.9% certain it would fit.If you tailgate doesn't have the holes drilled already,then the outer ones are already marked,all you have to do is line them up and drill the centre ones.
Easy peasy,although make sure the rubber seals around the mountings are there otherwise you'll end up with a boot full of water.
