Hi there hoping someone can help . Rear wiper on my 04 sport tourer has seized ,motor appears to be working fine , is this an easy fix or a trip to Renault garage ? Any help would be great .
Hi there.
I would remove the motor, then see where the jamming is occuring & take it from there.
It may just be a dry joint coupled with lack of use.
But trying to move the wiper whilst still attached to the motor could cause damage to some linkage.
HTH
Paul
Yes I tried motor separated from wiper assembly and works fine , would appear to be wiper assembly that's seized ,bit wary of removing it as attached to actual rear window
D
Usually if you undo the wiper arm nut, and undo the motor mounting, you'll be able to twist / turn / wiggle it through.
They're on a taper, so will be tight to start with. You may even get away with just drowning it in wd-40
