Coolant Temp Sensor
HI CAN ANY ONE TELL ME WHITCH ONE IS THE COOLANT SENSOE IS IT THE GREEN TOP ONE ARE THE WHITE ONE AT THE BOTTOM OF THE TEMP HOUSING :crazy: :crazy: :crazy: AND WHERE CAN YOU GET THEM I HAVE TRIED THREE SCRAP YARDS AND HAVE NONE
DOES ANY ONE KNOW WHAT ONE OF THE TWO SENSORS IS THE COOLANT SENSOR ON THE TEMP HOUSING THE GREEN ONE ARE THE WHITE ONE UNDERNEATH :crazy: :crazy: :crazy: :crazy: :crazy: :crazy:
Hi Mally1888, not sure, but with Renaults the one with the green neck is usually the oil pressure switch, are you sure they are both on the thermostat housing?
Hope it helps :)
they both are they are a right side of engine one at top of housing and one at bottom if you check ebay there is a laguna one the same but its for a drev
