The voice activation button on my Left hand stalk [ indicator stalk] does not work. One minute it was fine, the next time I pressed it nothing, Any bright [ or otherwise ] ideas?? My car is Lag 11 Initiale
everytime I press mine it makes two beebs and thats it.
I followed step by step the instrucions in the hand book but still the same. I dont have yet the sat nav dvd(the disc) so I wonder if that's the problem.
Surely the voice or non voice switch is the first swtich on the righthand side of the steering wheel on the lower dash pane, do you have a manual for the car.
Pete
My laguna has a switch on the right hand side of the dash, if you want to hear the ladies voice then you have to press it when you start.
I had a problem with a loose connection on the back of the switch, I had to carry out a bit of soldering.
It may be a loose connection on the stalk
