hi
just noticed a small puddle in boot on 2001 estate, water is dripping from light fitting, Im sure it is coming through where the GPS antena is fitted
how do i gain access to this and any sudgestions on what to use to stop it
cheers
Assuming that its coming from there, replace the rubber grommets and seal on the inside with silicone sealant.
remove the light fitting in the headlining in the boot and the nut that holds the gps antena is above it there maybe a piece of sponge stuck to the light or in my case came off when i remove the light
