I have a leaky sunroof on my Clio, does anyone have any ideas on how to fix it?
Also is it a pretty common problem?
tilt or slide ?
if its slide you can get in and reseal from inside if its tilt you have to remove it
i take it its leaking at the glass?
ure ariel is there reseal all round the ariel from inside and silicon the outer ariel base or fit new rubber to base of ariel. it will knock out your cental locking if you dont rectify it
