can anyone help?
i have a renault laguna 52'plate with electric sunroof. i recently discovered that water was getting in via the A pillar running down inside the cover and onto the fuse board which shorted out the electronic key fob and steering column control unit, which has cost me alot of money to replace. The problem i have is taking down part of the headlining to ascertain whether or not the overflow pipe on the sun roof is blocked or disslodged. Is there an easy way of removing the holding clips holding the headlining up and is there rainwater pipe coming from the sunroof and does this pipe sit inside the A pillar and run out of the wheel arch ? also the sun glass holder above the drivers head appears troublesome to remove without breaking any plastic clips etc.
many thanks and i hope to be of assistance with any future problems.
