Hi, Can anyone tell me if the window gaskets are made of one profile, or two? I've got leaks and I have sealed around the outer edge, but water is still getting in somehow.
Thanks for coming back. They are the original renault bus/ambulance windows. I have since gunned MPH Seal Seam into the outer lip of the exterior rubber, all the way around each window. It has rained since quite heavily and I can see a small amount of water dripping in via the bottom corners. I am thinking of gunning a fine bead of black or clear silicone externally, between the glass and the rubber. It could get very messy!!
