1 - 14 of 14 Posts
mk2 Laguna 2001 y plate
wont unlock the central locking - any ideas
jeycard lights up when button is presed but nothing from the car
what are the options to a - get into the car
and b sort longer term
finger slip I think:rolleyes: :rolleyes: :rolleyes:
Hi on my keycard i can pull it apart from the corner and reveal a key, think if you look at the underneath of the passenger front door handle they should be a little hole for you to insert the small key this should let you get in the car.
Hope yours is the same.
Dave
no only got one key card with the car
and the small key u speak of yes I have but it has not been cut to the car
its not a replacement keycard from ebay is it?if its the original then it should be cut for your car
nthesx
to be honest I don't know
it came when we bought the car - it could well be a replacement as the small key is green - that apparently means it's
I do have another laguna key but it's not programmed to this car - lol the wife tells me its in the car !!!:steam:
oh dear...maybe you could contact renault,they my be able to supply you with the correct cut key(at a price)which will get you out the $hit.a new keycard from renault will cost about £125 i think,but dont buy a replacement from ebay,there is a thread on here somewhere about them.other than smashing the glass i dont know what else to suggest.
regards
nthesx
Yes, can confirm to you a new 2 button Laguna keycard is £75-13 + programming fee (£30, allegedly, but I blagged my local garage to do it for free, as I'd just spend £700 on other things...). You will need the V5 and ID to order a new one - expect a 10 day wait as they come from Renault in France!
Good luck
Paul
PS. just how do you manage to lock a keycard in the car? :)
Discussion Starter #11
no the key card in the car is not programmed to this car
the programmed keycard wont unlock the doors - flat battery (only 6 weeks old)
glass smashed and charging battery as we speak
car battery or keycard battery??6 weeks old then i would think its alternator probs and not battery.
smashed the window in the end,ring the insurance in the morn and get them to repair it yeah
good luck with ya cardkeys
nthesx
Discussion Starter #13
key card battery was replaced this am - wee red light was always working
car battery was flat - no central locking no dash clock etc
got enrty aand as charging battery - lights etc all working
car has not moved since last wed
so give it a good charge now
see it will stat after that and then call insurnce about that bad man who smashed my window
1 - 14 of 14 Posts
