Can anyone recommend a reasonably priced supplier of brake discs?
I've seen some prices that are more than DOUBLE what others are charging.
Thanks.
Any major motor factor should be able to supply competitively priced brake parts.Check out the websites of GSF and Eurocar parts as they have catalogues online with prices.Failing that,if you have a local Partco,then try them.
Are you looking for front or rear discs?.If it's rear discs your looking for,then things can be a little more complicated as some discs will come with wheel bearings already fitted,others come without them and you have to swap the old bearings into them.This could explain the cost difference.
Also,it's worth spending money on a decent set of brake discs and pads as they will perform better and quite possibly last longer.There are makes that I would personally avoid.......
I should have said that you could try one of our forum sponsors(Shop 4 Parts) too.:eek::)
Scatz,I'll be in touch.:)
