For approx a month I was experiencing a loss of power at about 2000 to 2500 rpm in any gear. This seamed to happen 5 minutes from cold every day and would not repeat itself when the car had warmed up. Having the idea from your forum about the EGR valve becoming clogged up. I was going to look at this but found I had little time to spend on this so I got the car into Renaults.
The result was an EGR valve that needed cleaning for the cost of £147.94.
In future I think I will include the cleaning of this item and hoses, when I service the car, perhaps around the 54k mark. This fault appeared at 89k.
So far the car runs fine, early to tell, but hoping.
Hi it does pay sometimes to clean and DIY the job if you can i just cannot afford Renaults prices i also use a independent garage but only if iam beat
