Hi! Just wondering if anyone can help. I currently drive a Renault Laguna II (2001) 1.9dCi. Sometimes when I am accelerating the yellow glow plug light comes on and I immediately lose power. I then have to pull over, turn off the engine, remove the card, re-insert the card and restart the car. The glow plug light will then stay on until the revs go above 1000 and then the car is fine again until the next time. This usually happens at least once a day and usually on the motorway. Has anyone else suffered with this problem that can give me some advice? Thanks
Remove the Soot and ¤¤¤¤ that is blocking the EGR valve and the inlet manifold port where the valve was removed from..
EGR Valve
Webcode,
Many thanks for your advice. Could you tell me where I can locate the EGR valve so I can clean it? What difference will cleaning the EGR valve make?
EGR valve on laguna 1.9 DCI
Please could anyone tell me where I can locate the EGR valve on a Renault Laguna 1.9 DCI? Also I would be grateful if you could give me some advice on how to remove it.
SKG
