Hello,
I lost my ONLY key for my Renault Megane Coupe 1.6 -'96.
I dont have pin and i cannot start my car.
How can i proceed.
I have bought another key and locks from Scenic and change them but still have the problem with the immo. PLS tell me how to start my car???
R
The 2nd hand key you have will need programing to the ECU and if you don't have the PIN then you are going to have to get the PIN read with diagnostic equipment. Looks like your going to need the services of an auto lock smith :(
L
Second hand key cannot be reprogrammed, you need to order a new plip from Renault, about £80 plus programming.
I would put the old barrel back in and do the above.
If you want to use second hand parts you will need the ECU, and the fusebox from the donor car.
