Last week i had a stop warning along with low battery beep/light up on the dash of my 05 scenic. At 1st intermittently but now it stays on. I've not used the car for a few days since the warning came but it starts fine but the warning still comes on
I've had one or 2 friends (works at local garage)take a look and when they've tested it, its pointing to a problem with the alternator.
They said something about it could be an intelligent alternator that turns off if theres a problem and can be reset or adjusted instead of being replaced.
I was hopng someone could clarify this and suggest helpful solutions. I've done a search and found a few people with similar problems but can't seem to find the answers I'm looking for
I dont want to get the alternator replaced if I dont need to (this car has cost me enough in repairs already since i've owned it)
Barrelreef
Hello Barrelreef
I have a 05 Grand Scenic and I'm having the same problem, just been quoted £650 for a new alternator. Have you solved your problem and if so how?
Mark
