I have a 2003 Mégane II 1.6 auto. In the last couple of days I have had two problems 1. The driver side rear window will not open and 2. The radio will not switch on. I can't find my handbook but located the fusebox beside the glovebox on the passenger side. I replaced the radio fuse but it still doesn't work. It is not clear which fuse covers the window in question. Any ideas what is causing the problems?
Hello & Welcome to the Forums Joolsveer.
I'm sure someone will be able to assist with your post shortly .
Ottoman
You do not say if the Radio fuse was blown?
The Window sounds like a local issue as the fuse that protects the circuit covers all the windows. It could be merelt 'stuck' Can you hear the relay trying to click or the motor trying to turn?
