can anyone help.???
i have a 2005 trafic. symptoms are low power until 15-2000rpm. then a bit more power then get to around 2800-3000 then slight hesitation. i have replaced fuel pump solenoid fuel filter map sensor and boost solenoid also i purchased a MAF sensor from a local motor factors for i think was £60 but when i unplug it while the van is running it stalls is this correct or should it still run without it plugged in??
thanks in advance!!!!
