I have a 2006 scenic.
Should the main beam flash when you pull the stalk a little way or does it only work when you pull all way to put on main beam?
Mine only works when I pull all the way so I have to click the main beam on then click it off again with a double pull when I want to flash someone.
hello it should work it may be the contacts within the stalk are worn and are not touching but when you put the full beam on it is on a fixed position so the contacts are forced together
its very strange. when no headlights are on i pull on the left stalk and it clicks and flashes main beam but when released goes off.
But when on dipped headlights and i pull on stalk it clicks then stays on main beam (obviously).
But there is nothing until the click.
If it is the stalk is it repairable or do i need a replacement and if so how easy is it to replace?
hello it should be straight forward if its the same as most cars take of the shroud there should be a couple of screws and a multi plug take off and replace in reverse good luck
