hi , i have a 03 1.6 16v megane and have not got the key to remove the centre cap, how do i know if i need a male or a female one thanks
steph:confused:
You'll need a male key - one with pins.
The one from the laguna 1 that once had looked like it would fit that.
Do a search on good old fleabay for alloy wheel cover key.
The Vauxhall one is the same and usually much cheaper.
In the meantime a pair of pointy-nosed pliers usually does the trick.:)
