i own a megan 1.4e 1998 and unfortunatley the cambelt has snapped i strongly suspect after inspection that the valves have been damaged in the process.is it worth removing the head and renewing the valves etc or to install another head assbly
Hello & Welcome to the Forums Marc.
I think you have to way up the pros & cons of cost, time and where do you get a good cylinder head ?
Ottoman
Hi red99999 I think it depends if ...
1/ You can do it yourself
2/ Your interested/up for the challenge
3/ You've got the time
4/ The extent of the damage to the head .. OK if only valves ... bad if the guides etc need replaced .. just depends.
5/ Difficulty in getting a head thats A1 ... you might be buying in other problems, pitted/burnt seats etc, again ... just depends.
6/ Outcome of examining the pistons ... hopefully no damage/liners (this is a wet liner engine .. ?) ... damaged ... start crying now.
hope it helps :)
