I wonder if you can help...
We have a 2005 master 2.5 DCI that will not start...
The van was not used for 2 weeks and when we came to start it it would simply not start, turns over fine, but that is about it...
I have tried hand priming and bleeding the fuel system up to the filter as it is the engine without the in tank lift pump....
I did manage to get it to run for a few seconds by continually pumping the priming bulb.. but that is about it...
We had another van prior to this, a Movano, and had exactly the same problem, but after removing the tank and checking the lines, fuel filter etc, we put it back together and it started running again fine.... so not convinced it is the pump just yet...
Are there any tests I can do without a code reader?
