Hi all
My friend has a 2020 Renault master the rear brake pad fell out onto the wheel resulting in caliper piston leaking fluid out and draining the master cylinder now put back together but can't get a brake pedal but getting fluid out of all calipers is there anything else I can do ok please.
Trafic
Speaking from experience with a car just wondering how you are bleeding the brakes? As with the two man on/off pumping the pedal it maybe an airlock that it just moving back and forth usually along the longer length pipes to the back of a vehicle which is likely to have happened with the total loss of the fluid. Have you tried using something like a Gunsons One Man Eezibleed Kit where the fluid is pushed through via air pressure from a tyre connected to the reservoir? Garages with air compressors are likely to have a brake bleed vacuum kit which connects at the brake nipple end which creates a vacuum and pulls the fluid through the system.
