Hi, I’ve got a megane alize 1.6, S reg. On the motorway the battery warning light came on so I assumed the alternator belt had gone so headed to nearest service station. As i got into the service station I got a nice bang and the engine cut out. Looking inside the alternator belt had gone. On later inspection the cam belt is pretty ripped up - it's still there but almost split through. I'm thinking that the alternator belt went but was lodged inside, then managed to damage the cam belt (luckily only when i got to the service station - the engine cut just as i was reversing, possibly this moved the damaged alternator belt?).
A few questions - How did the alternator belt damage the cam belt as the cam belt cover wasn't damaged?
What to do now? I assume the valves could be pretty bent up? So the cam belt would need changing and possibly valves?
I’ve put the car in gear and rolled it forward - the cam belt is there enough to move and I couldn't hear any noise from the engine.
I'm also assuming the cam belt has slipped a bit?
So, the main question is, what to do now?
My biggest problem is that the car is at a relatives - about a 100 miles from home.
Presently, I'm thinking of scrapping it, but it’s only done 40,000 miles so it seems a waste. If I could get it towed back to my house I was thinking of trying to sort this out myself. I know it’s a lot of work, but I don't want to spend cash on paying someone to fix this, but think it could be a good way to learn, and, if it goes wrong all I’ve lost is the cost of the tow (which could be covered by the scrap cost anyway..)
The other kicker is that it was only serviced and MOT'd 4 weeks ago, and the cam belt was changed about 5000 miles ago. I only took ownership of the car a few months back but it’s been in the family since new before then.
Thoughts and opinions are greatly appreciated. Thanks.
