I have replaced the fan and wiring loom etc for the cars heating and the fan is functioning correctly.
The problem is that little to no air is coming through the vents.
Any help would be much appreciated.
Alan
Hi Dancingdad
The pollen filter has been removed, at some point before I bought it, for my daughter.
The blower fan has never worked, so I have also replaced the fan itself.
got the wiring the correct way around, not reversed polarity on the motor, and its spinning backwards.. Pushing air out, instead of pulling air in..
Can he Red And Black wires going on to the motor be reversed ..
As in,, will fit either way...
If yes pull them off and reverse them... see if its that..
pipe work to vents are back on,,
The wires will only only go on one way. I will check all the pipes etc.
Thank you
