Had this problem for some time but has started to get worse. At idle the engine shakes quite dramatically almost as if on three cylinders. You only have to touch the throttle and the engine seems to sort itself out. Whilst I first thought engine mounts Im now not sure as turnign the air con ON picks up the idle a little and stops the shaking. It has also started to misfire slightly under very low revs with little acceleration but NOT under load.
I have had to do the whole EGR clean out (and blanking off eventually) on a previous car but dont remember the symptoms being like this.
Any ideas would be appreciated.
Aaron
Aaron
