Hi All
I am changing, Cambelt, Water pump, Dephaser Pulley, Aux Belt at weekend. Also have an oil leak from cambox so will be removing that also. (Both parts of the cams)
Have all the locking tools but do require torque settings for it all.
2005 Megane 1.6 16v Tourer.
Many thanks if anyone can help.
remember Murphy never sleeps
hi think you need a manual,camshaft phase shifter center bolt 75 nm.
idler pulley 45nm
tensioner pulley 27nm
camshaft sprocket nuts stage 1 30nm stage 2 angle tighten 115deg+-15.any more? Cheers
Thanks for the torque settings.
Had a friend look on Autodata and has printed off some figures too.
Crankshaft Pulley/Damper 40Nm + 145 Deg
Camshaft Sproket/Gear
Inlet 100Nm
Exhaust 30Nm + 84 Deg
