Hi, I recently bought this vehicle. It runs well, idles around 500rpm according to the tacho, and is slightly 'lumpy'. Difficult to tell but seems to run pretty much ok apart from that. I want to get the plugs out and check them, maybe swap to iridium anyway, but also understand there's a sensor in the exhaust that can affect it - is it easy to find? If I can find it I'll see if I can give it a clean. I'll be towing a mini-caravan over easter and want to be sure it's as ok as I can make it before tackling any big dorset/devon hills.
Also, can anyone recommend an equivalent model haynes manual for mechanical stuff?
Thanks.
Thanks.
