1 - 1 of 1 Posts
This is a FYI type thread rather than my usual question asking ;)
I noticed the other day that the boot on my Megane was not closing. On further inspection I found that the latch had fallen down inside the plastic casing meaning that the locking mechanism had nothing to make contact with. I took the casing off and found that the original plastic lugs that hold the latch in place had broken into several pieces leaving the latch free to move around.
A quick call to Renault showed that this was going to be expensive to replace, £61 for a complete latch as they do not sell the components separately. After picking my chin off the floor I decided to start researching alternative fixes and stumbled across these in a local Halfords:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_223305_langId_-1_categoryId_165562
The 8mm grommets fit snuggly over the ends of the latch and, with a bit of lining up, fit perfectly into the recesses. A bit of a bargain at less than £2!
I'll try and post some pictures later.
Olly
1 - 1 of 1 Posts
