HELPPPP...please if anybody has come across this problem and can help I will appreciate it.
My Megane is jerking like the fuel is over and this happens mostly in the first 3 gears. Also note that this happens when the temperatures are high. The diagnostic renault software gave an error on the down Oxygen sensor and I have replaced it but the problem still persists. Also, we have checked the catalyst by bypassing it and I still have the same problem.
might be worth checking the coils and the tdc sensor as these are quite common probs and can give similar running probs as you describe
regards
nigel
