Hi, I have a 2000 Megane Cabriolet 2.0ide which started running on 3 cylinders a while ago, I've got a new fuel rail which is going to be fitted this week, however I've also had a starting issue lately...the car starts fine first time and runs ok (considering its running on 3 cylinders) but if I return to it and try starting it it won't start, I have to leave a while then try again, it does eventually start again but its a little annoying when you pop to the shop for milk and have wait 20 minutes for it to re-start again, it doesn't do it all the time and seems a bit random, I have no idea what this could be...or if the problem is connected to the fuel rail, maybe it will be fine once the new rail is fitted.
Does anyone have any advice or info on this problem, has this happened to anyone else?
Thanks guys
Thanks guys
