hello everyone. as a new user i thought i would post this info; after searching several sites to solve a problem with my megane i found your site.
the problem i had was that my megane would start but then cut out straight away if you did not play with accelerator pedal but would run after about 30 seconds but lumpy with low idle speed. the fix was to remove the electronic throttle body and idle control vave ( a sod of a job) and clean with carb cleaner & remove carbon deposits, the car now starts & runs as it should.
thanks
peter
thanks
peter
