hi guys - i get erattic idling and engine cuts out on my megane dci...ive cleaned the tdc sensor on the bell housing b ut still does the same...i thought id try the crankshaft sensor located on the timing belt side, i can see it but cant seem to get at it see pic please..i understand i need to remove the timing belt cover, i can unclip two of the clips on the top half of the cover, but how do you remove it...it seems that i need to remove the mountings as it seems to go through that..see second pic...any help please...ta
