I'm Faizel and I've had my megane2 for a few months before the "check injection" light came on. To date I have :
Changed all the plugs/ replaced map sensor and o2 sensor/ had coils checked/ replaced fuel pump at the advice of the mechanic- worked for a week albeit rich in fumes/ then it started the check injection again.
At my wits end - the mechanics don't seem to know any better either...
Bought and OBD2 scanner on souq.com but its doesnt register with a 2008 model megane.... only renault code reader will do and they charge an absolute fortune....
Any help ?????
Can you explain what the running issues are, check injection light could be for anything..
You say your scanner does not connect, what sort of scanner is it, is it an ELM based interface, or a hand held scanner
