checked engine bracket, exhaust system. the engine is running on all cylinders. furthermore when driving in highway speed is the engine unusual noisy.
Could it be timing belt or VTT valve or gear. Can anybody help me?
What actually happened?
Really not enough info given..
Rough idle and vibration at idle as well as high speed or?
It is very strange. The engine seems to go hard in idle, with vibration that your can feel in the car. The idle is a little bit higher then normal 1000 r/m. When your drive the car at normal speed at highest gear it fell like you drive at lower gear. That because the engine is very buzzy. There is normal power in the engine.
