1 - 1 of 1 Posts
hi thanks for looking - have 2x megane 2. Passenger front window not working but motor is, Have 12v across both switch wires when operated, the same as drivers side which works fine. So swapped out for known working mechanism from other car, checked worked on offside ok but still no operation on near side. All voltages appear correct same as offside, 12v on center pins and both switch wires when operated. 0.17v on 5th wire on both sides but not sure of its purpose. Have disconnected battery but can't work out why correct voltages but no operation with a known working module. If anyone has any ideas would be much appreciated, thanks
1 - 1 of 1 Posts
