Hi all this is an amazing forum I managed to fix one problem which was so easy and turned out to be such a simple thing and would have cost a bunch of money to take it in. Now here is my problem every time I start the car I have to reset my car radio channels and the time clock on the dash keeps resetting, it can be rather frustrating and ideas, all ideas welcome
In No particular order. Battery, Terminals, Earth strap, Starter motor connections.
Battery under drivers seat?
The radio has ywo fused circuits - one permanent and one ignition fed. If the fuse on the permanent feed fails then the radio will not be able to retain its memory each time the ignition is switched off. Sorry I don't know the location of the relevant fuses on your model.
2 fitted in the inside fuse box,, From the bottom 2nd row up 5th from the left, as you look at it..
2nd row down 3rd from the left
