Hi. I am preparing to change gearbox oil in my megane 3, 2010, i have TL4 6speed manual gearbox. Will buy oil Tranself 75W80 NFP or NFJ, but dont know how much is capacity. Somewhere i read 1.9 litres, on other site 2.3 litres, don know to buy 2 or 3 liters, it is not cheap oil. Have no autodata so please if someone can check capacity. Thanks!
I've rechecked your specs with my data sheet.
TL4:
Capacity: 1.9 Litres.
Oil: ELF NFJ 75W80 GL-4.
Drain plug (8mm square) torque: 24nm (with copper crush washer).
Did you follow my suggestion on the above post?
yes. all working good.. 1.9 or 2.1 litres is not a big difference.. maybe car was on some angle lifted.
