1 - 12 of 12 Posts
Hello! I want to install a net-luggage retain: "dog guard". My Tourer dosent have the plastic covers (anch high load). It's possible to install it?
Wow i am sure it will make a big difference, everyone would notice for sure..... good luck
Captur 2017 1.5DCi EDC
I use the Halfords three-piece one that clips onto the rear headrests. It's very secure, looks OK and is quick to remove if I want to use the boot space for longer loads. It's also massively cheaper than the Renault offering.
Without the plastic covers the guard will have to be braced against the trim. I have never found this satisfactory. Have you checked what Renault's solution might be? And is this going to be a permanent fixture?
I found this, on line, but my problem is: does the car have any suport wellded on the chassis to attach the part nº5?
179346
Sorry, can't say for sure but if you don't have the removable covers over the trim I would not expect the fittings to be there. Only way to tell is to remove. Then eventually you will have to cut away the trim to mount it.
Discussion Starter #10
Well... I think that to...
That's your opinion.... Mine is a little different.... And by yhe way: I ask for HELP not OPINIONS!!!!
I find your reply to be very abrupt towards Mikeyjp, who is a respected long term contributor to the forum. You asked for help and he gave you a potential solution (post #2). His "opinion" (post #4) was simply just his reasonable justification as to why he recommended his solution.
Back on topic, either go aftermarket or call your local Renault dealer for the standard part.
Discussion Starter #12
As I said before: ask for help.
1 - 12 of 12 Posts
