21 - 25 of 25 Posts
yes but they will be on permanently
can you get the plug off the back of the head light unit,
ITS number two wire , if you can get the plug off, and look at the plug face on, its the second wire in from the left
Discussion Starter · #23 ·
I want the white to be on when the ignition is on so it's a second DRL. The fitted DRL would be ideal, but I can't get to it.
I can get to the headlight cables fine. I've tested and spliced onto the indicator cables both sides.
Is there another cable I can splice to for ignition only power?
Not that I can see from the fuse box diagram,
Any you piggy back off, because its a switching unit you could do damage to the fusebox
Not very robust these under bonnet fuseboxes ,
Looks like you need to get to the interior fusebox, to be safe, and not damage anything
Discussion Starter · #25 ·
That's not an option. I'll need to get under the car to get to the DRL.
Thanks for your help.
21 - 25 of 25 Posts
