And can you change the characteristics easily?
I decided I want a 2010 - 2012 Megane Coupe. I just do! Originally thought Audi TT but decided they are a bit obvious.
I can't thoil** renaultsport, and the Mrs will go barmy if I spend much over £4k as we don't really need a second car.
so. in a coupe, is there much difference between GT, GT line, and Standard suspension? I'm not much bothered about trim.
**Thoil. A Yorkshire dialect word. Basically, you could find the money if you had to but you are too tight to spend that much on whatever it is.
you can get 2nd hand RS springs and dampers for about £100, GT will be a bit better than standard, but wont be ground breaking
